  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
episode 1
he didn't own any
c3po was anakins
r2d2 was amidalas
episode 2
c3po the lars then anakin
r2d2 amidala's
so prey tell when did he own a droid
and if u try and swing the on in the jedi starfighter your wrong
that driod is intergrated into ship and can't be removed
it belongs to the ship and obi wan didn't own the ship so he still hasn't owned a droid
Originally posted by Boostzor
R2 Was originally on amidalas cruiser right? and c3po was built by anikin? so saying he doesnt recognise em is BS
Ok no semantics
true but obi wan never saw c3po sa golden rod as yet
r2 astromechs are very common and don't have unquie colorings same goes for 3po driods
and he never says he doesn't recognise them he says he doesn't recall owning any droids
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
