  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
19 years has a GTR - nice! got work to do to catch up but i want an R33 GTR actually stuff it i just want my car to go 10 times faster - hmmm i want too much!
Ken - well as long as he hits a home run - if he's only a first baser its not worht having him on the team haha :P
First baser , with you around he won't even get the bat out of his bag. Hehehe
Cheers
Ken
Originally posted by angel
It is all very clear now. Anyone recommend a good book?
Clear , I'm confused as hell . Gotta find out what sort of drugs you use ? Can I have some.
And are you coming Sunday angel?
Cheers
Ken
Originally posted by skyzerr33
hello peoples :P
so why are u belching ken
Uhoh , run Angel while you have a chance, we may never leave the gutter again cos Troy the Start Warts nerd is here.
Belching ? wtf ?
Cheers
Ken
Hey Ken, could I take one of your GTR's for a drive?
Angel , at this exact moment , I only have one and it's a non goer.
But ask me next week and I might , just between you and me , ok.
Make sure you don't tell anybody else.
Btw , how big is your husband.:P
Cheers
Ken
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
