  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
Angel , at this exact moment , I only have one and it's a non goer.
But ask me next week and I might , just between you and me , ok.
Make sure you don't tell anybody else.
Btw , how big is your husband.:P
Cheers
Ken
Ken wants "favours" in return for driving the GTR Angel - be very very careful haha
Originally posted by Nizmo
i think he should let me drive it - the clutch will never be the same again hehehe! :P
Yea , your right , my crutch would never be the same again.
* looks again *
Ohh sorry , you said CLUTCH !:P
Cheers
Ken
awww niz , you don't know me ( unfortunately )
I'm all bark and no bite. Well maybe just the odd little nibble
:P
Cheers
Ken
Originally posted by angel
Ken are you the one who teaches driving? Would like a track session to learn how to handle my car better.
Think we could get enough people to have a track day?
Track day at wanners you couldn't afford.
Micko is getting a few people together for an MC type training day.
Cheers
Ken
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
