  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Adam, the training is on a skidpan with different 'courses' laid out with witches hats which are designed to teach you how to drive on roads that aren't straight as if they were (sort of anyway).
On the normal MC training days they have up to 20 drivers/cars over the 3 hours - the one we are looking at will mean we have 5 drivers over 3 hours.
Simple math tells me we will learn more.
I assume that was more along the lines of what you wanted to know?
If there is enough interest I will organise one of the regular training days cos they are great fun with a big group & if we did the morning session we could all go to the pub after for a good counter meal, beer & brag about our skills (& take the piss out of macka:))
That would cost us $55 each & last time we did it we had an absolute ball.
Will definately put you down as no2 on the bench.
You guys should come out & watch us anyway - I always come down to watch everyone else running at the drags.
Originally posted by skyzerr33
how much for a head gasket? stock
installed me thinks thats the deal
its not missing
but the water i put in is now a mecky brown and then a hiss (air escaping noise) when the car is running.
Got your message but I am not sms 'ing the answer.
Hissing noise , from where.
Cheers
ken
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
