Originally posted by GTS-t VSPEC
His mind improved? I don't think so, he keeps asking for my advice, an obvious sign of insanity:p
See'ya:burnout:
yea , he asked your advice and then rung me for a closer to the truth answer.
Cheers
Ken:D :P :shake:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Fremantle is the start of the cruise, although we are meeting with NOR people further up:D
See'ya:burnout:
there is a south of the river ??
Wouldn't know these days , don't go there:D
Cheers
Ken
Ken,
Did we end up at the same conclusion, headgasket?
Troy,
Your a cheat and everyone knows it:p
See'ya:burnout:
no u didn't
and your the only one that thinks i'm a cheat
whoring is whoring use all the dirty tricks u know to win hehe
Ken,
Troy,
See'ya:burnout:
No , buggered Rad cap atm until Troy can pinpoint more things.
Very hard to diagnose over the phone with someone who can fix a computer but can barely find a dipstick:D lol
Cheers
Ken
Rad cap? Suppose, but would you like to wager on it:D
See'ya:burnout:
nothing
just out od interest how much is metal 2mm headgasket?
i've figure about $700 all up to replace the stock one with a stock one if thats the case.
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
