Boostzor keeps pestering to drive on the cruise this weekend. But the 'line told me in private that he hates when Boostzor drives him. I don't blame him, Boostzor fights with the clutch like a grandma vs a slot machine. Its painful to watch.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
