  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
These guys are business men who have no time to work on , look after or run there cars so Maximums provides the infrastructure to make it happen.
We have Rob himself
Brad who owns an Auto One store
Graham who is a Lazer eye specialist
Adam who is a Chief Mine engineer up Laverton way
Shane who is an Insurance and Investment adviser ( an ex E Perth footballer . I think )
Is the first and second round of the W Aust rally championship and the first round of the Aust Rally Championship.
So yes , Possum bourne , Simon evans , Ed ordynski , etc will be here.
Cheers
Ken
Originally posted by Sneeza
Did you do that??? I didn't even know!! Thank you Ken *hug*
Is that better :P
I may be a wisecracking old fart but I do have a soft side , especially for females:D
* shaddup Paul *
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken,
That was a pretty accurate recap, but Niz and I haven't been having our usual chats:p
See'ya:burnout:
why ?
She realised she wants more than a 1 minute stand ?:P
Cheers
Ken
Ken,
Thanks for filling me in on the rally stuff, I do like it, but rarely go to the local events, just WRC.
My mate from Drivetime TV will be there, do you want to be on TV, and be famous like me?
See'ya:burnout:
err , I don't think so .
Tolley HATES my guts and is the only person in Rallying who will not speak to me.
Which I find just perfect, the slippery , bill dodging little greek.
Cheers
Ken
I appreciate it Ken - you do offer good advice as well!
Paul - why haven't you been having your usual chats with Niz?
Awww * blush , blush *
I do try and then some people say I am very trying:D
Cheers
Ken
Ken,
You know what Troy is like, he'll probably delete your post so you don't own a page:p
See'ya:burnout:
Yes but I have witnesses unlike Troy who adds to his post count when we are all in bed.:P:D
Cheers
Ken
riiiiight Ken - so nothing out of the ordinary then hahaha
Oh my goodness - Nitro funny cars are back this weekend!!!! I love those things! I spend so much time down the plex - I actually hate the place hahaha
Ohh and terribly soory.
We were so busy whoring , didn't see that post.
Niiiite Sneeza.
Sleep well and don't worry about next w/end.
It will always turn out good , weddings never are a disaster cos it is such a happy day for everyone.
Cheers
Ken
Hehe, thought that might be your response:p
Tollie isn't my friend, just a guy I lent my car to once:p
I'm sure there's plenty of people who hate you:bahaha:
See'ya:burnout:
Paul , there are people that hate me , you don't get thru life without creating enemies .
If you do then you are just a mat that everyone walks on and over.
Tolley just makes it very public and as most people say later , he sees the problem every morning when he shaves , just too stubborn or arrogant to admit it.
Cheers
Ken
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
