  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe it wasnt a servo it was where the service dept of new town toyota where i used to work - which even worse - they know me :D But i had a couple people say they were really worried it was coming from there car til they saw it was mine - so least im not the only person that starts getting anxious at the smell.
haha just before the R34 went up in smoke joe goes to me "do you smell burning tyres" im like "who cares as long as its not frommy car" then black smoke starts pouring out the car in front oops.
Originally posted by GTS-t VSPEC
Niz, Ever heard of a car jack?:bahaha:
I got page ownage Troy:p
See'ya:burnout:
considering a friends of mine broke while he was under the car and nearly killed himself - im not going there! but if you want to have a go - be my guest :D
i just hate anyone thats in my way :D Apparently you get road rage as much as i do paul - say sneeza anyway - ask joe i curse n swear and talk other drivers thru the process of driving...... haha i think i seriously intimadated a learner driver, after a while she got the hint and pulled off the road haha poor thing.
Good luck with the interview russ - whats the job?
haha my mum does the hand gestures - i learnt from the best road rage instructor in town.
Yes well i was getting to the yelling point - probably wouldve (specially at stoopid toyota echo doing 50 in 80zone pffpt) but joe was in the car and i didnt want him thinking i was a raving maniac.
Originally posted by 33Spec2
Shell servo will b my second job mite try 4 three jobs!
hahahaha sneezas impersonation of paul - 50k per hour 40k per hour! OMIFUC*INGGOD 40k PER HOUR!!!
^ funny cos it was what i wa saying to echo "We are doing 50 didnt say 80 back there WE ARE DOING ***ING 50!! wish this arsehole would get out the way - does he even know where the F-ing accelator is - wanker" haha
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
