Originally posted by GTS-t VSPEC
Improvise,
Glad you enjoyed the car, but hardly necessary to start a thread on the subject.
See'ya:burnout:
I really don't think that is harsh. I just pointed out that I didn't believe he needed to start a thread about it. I did appologize to him in case I hurt his feelings.
See'ya:burnout:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Anyone installed a GPS System from Japan into their Skyline?
I just imported my GTS-4 and it came with a Sony GPS and TV Screen. The local car stereo place said that the equipment was basically useless and won't work here.
Anyone else encounted a similiar situation? Any information would be appreciated?
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
