  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
kyles, tell troy thats it's only when i'm with him :P and it was suppose to be a secret! hahahaa enough of that! WHEN IS AUTO SALON I DEFINATELY AIN"T MISSING IT THIS YEAR are we goin down as a big group of hooligans to run a muck or wat?
adrian :)
awwww poor niz, where were u b4 anyways? you took ages to type a post unlike your whoring nature? heheheh :P
kyles whats wrong with your nose? ur gonna pay doctors to break it again? man they get the good life!
adrian :)
Originally posted by Kyles
oh... I saw the guy about my nose today.
Im getting major reconstructive surgery in a year. They have to break my nose again and then mold it back to place. They cant do it for another year because my broken bones have already started to heal.
Damm kids!... just dont get any complection Kyles...
you look fine :P
just had a few bits n pieces to do for work :) guess thats why im here. so ive been kinda floating in and out of the forum all day - plus found noone was talking to me - so why hang around :P
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
