  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahahaha how fast can one of those electric wheelchairs go?
imagine one with nos? aaaaaaaaaaaaaaaahahahahahahahahaha
if ya hate needles a instant burst of nos will get ya flyin outta the doctors office? especially if you got a crackcase doctor like that one of the simpsons :P HI EVERYBODY
adrian :)
Originally posted by Boostzor
What were u doing Psiker? please tell me it wasnt the old
"ahh im standing up and i have to slide this thing along the floor, i know ill just slide it sideways with my leg.....ahhh dammit that hurts"
Dont that b4, its a doosie
it would be easier to explain if you knew how a 8270 bowling pinspotter worked.
pretty much i was taking the bottom out of one. i had to push forward on the cushion with my leg while my pther leg was out of the machine. felt a huge strain and it got worse progressivly thru the day
vspec - hi :P
Psiker
Originally posted by Nizmo
yeah no probs joe 5pm! you will be riding home with an emotional female tho :P
uhhhh... tell uncle Joe your problem... A cup of Baskins Robbins Sunday will fix that! :( with chocolate fudge topping :)
You dont have to Nizmo, only if you are passing st.George's terrace :)
I'll be outside Infront of Bank west tower, st.george's terrace enterance :P
cheers
Joe
