  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yes its all coming together now.
1) drive at a safe speed. Don't take too much just enough to keep you 'alert' (see rule 8)
2)Don't drink and drive. Drink first, you can't shoot up the speed and drink and drive at the same time
3) Follow the road rules, because you add valuable revenue to the drug dealing community and help justify the existance of support groups.
4) Concentrate at all times (never cut the stuff down with glucose you are only cheating yourself) and be prepared (make sure you have extra in the glove box)
5) Be patient, when in doubt , don't proceed (If the clearence on the front spoiler is low and you don't think the dog in front of you will clear it , don't continue running it over -- stop and shoot it instead)
6)Plan your moves in well advance. Make sure you 'scope out' the good looker in the car in the next lane and think up appropriate facial gestures well in advance.
7) Give correct signals. Eg: The finger --- when you get cut off. The gun --- when they do it a second time.
8) Be alert at intersections. As per rule 1, use appropraite amounts.
9) Know your vehicle. Love is a beautifull thing.
10)Be polite and considerate toward other road users*
(* only applies to vehicles over 40 tonnes laiden with flamible liquids or gas and driving on the wrong side of the road)
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
