Good Morning...
Sneeza- I am so sorry to hear that you had another bad accident, soooo close to the your wedding and all.
I hope you will be alll riight. ;)
How bad is the injury...? If you need a lawyer I know few who might be take that case.
Skyzzer33- me no home breaker, Mr.Ken can keep own wife... :D
Macka- you tool dont forget the beers on that list of yours.
Nizmo- I hope you worken up already and there! as Ken said you will find sugar dadday eazzyyyy.... lol :bahaha:
Paul- I got no thing to say only give me lift to auto salon please :)
Russle- you need more power on your car :)
Adrrian- there is a gunmetal R32 gtst in carpark of shopping cenre, the guys is tossa, I think he works at shopping centre or at the jaster's
HAVE A GOOD DAY ALL!
cheers
JOe
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe stealth is good..
Yea I do have those rims.. I live in the city - used to live in North Shore - drive pretty much everywhere I can cause it's fun so you've probably seen me putting round somewhere.. ;)
I love the kit except for the rear wing.. am still not sure if I love it or hate it.. and it's been there since I bought the car!
pic here - http://members.iinet.net.au/~hongas/SAU/Cr...se/DCP_2067.JPG
I've already got the lip wing.. the other one sits on top.. just debating if I should take it off or not...
But for now I've got better things to spend $$ and time on than the body.. go fast bits are much more fun.. ;)
thanks joe.. ;) gotta love that front end...
aidwin - 13.6 is fairly decent for those mods.. best i got on my first night there was 14 flat - but i think it was more operator fairlure than anything.. hehe..
thats with afc, itc, bleed valve set to 12.5 psi, K&N pod and cat back exhaust...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
