  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ahh buggered if i know, its running on all four now which is good but low and behold after its maiden run i open the bonnet and there is oil all over the place. there is a leak somehwere near of behind the CAS cover and its spraying all over.
The coke bottle worked good though ;)
Hopefully ill take of teh CAS cover and there it will be some little o ring or something taht obviously need replacing. Either that or a big crack down the side of the block :eek: might need an engine upgrade :eek1:
Yeh that is where its coming from. Ya know the little oil breather box thingy? we we ripped that off and replaced it with a CPU heatsink (dont knock it it works) and from the little gap next to it u can see it all come out. Alot of smoke too
hmm well im not at home and i dont have adigcam so there are afew obstacles.
Ya know the valley with all the plugs and crap? well there is a little flat bit of metal on one side and a little box that sticks out of the rocker cover and joins the breather pipes from the intake to the ahhh other thingy. yeh that part
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
