  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
he giving me mesh and eyelids adn indicators for free! so i didn't say no lol!
and my car is white i reckon tustr front bad looks awesome!
i not putting it on till i buy some sideskirts though! i wanna find some sideskirts that are unique that noone else has!
adrian :D
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
