  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey all.. me back...
got the car up and running yet adam? any news on my can? :D
paul - u sure it's $100 for the polishing? did a bit of research, sounds a bit pricey.. still in for the exhaust pulley.. can't wait to get this stuff onto my car.. :)
paul - fair nuff.. will have to have a gander at urs when i get the pulley off ya.. :)
adam - wicked.. i'm very very interested to see how the beast goes - as i'm sure u are.. good stuff with the can bud.. thanks again..
so what else is going on? me just been reading rev's thread bout his car trying to achieve 12s..... interesting....
adam - every head i've seen done uses the sealant stuff..
paul - rev seems to have some interesting ideas.. i'd say his driving has alot to do with his times - but i like the philosophy behind it - don't go for max power, go for response..
Originally posted by GTS-t VSPEC
Brett,
Yeah, but they don't dress like these girls do:p
See'ya:burnout:
Partially true.... There is lots of class in the city and also some women that like to "dress down".... a good mixture for any young man :)
I think the key is that I don't like my women looking to "made up" like the promo girls always are.... I like a more natural beauty :D
