  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no im bored so i go to the go to the guy do u have anything u want me to do - and he said write a list of what you want to learn and i'll see what i can do about showing u. I dont even know what he does!?! So yeah inhouse - thing is when it comes ot admin - not much i dont already know. I mean i dont know what im suppose to be doing - i try to look occupied but just end up whoring with u guys which aint a bad thing but still im suppose to be doing something!
Originally posted by Nizmo
your meeting me there Troy.
Not lesso sorry - someone to come appreciate the male species with me :)
i can see it now u two are gonna pinch the digi cam and take pic of guys and hopefully cars and i'll be stuck being the walking wallet and handbag
hehe
u want to get into promotions right
put that on your list :)
Hehe... If it makes you feel better I know how you feel..... I do IT where I work so basically I sit on the net 8 hours a day trying to look busy :)
nice to see your rightful place in the world Troy :)
Digicam not a bad idea, Think i may have to pinch it off dad.
hmmm wonder how many guys i can post pics of to your girls haha
Hmmm trade and investment - all you can promote here is another country *yawn* I want to get into event mangement/public relations which yes i can do here - but the line of work doesnt interest me it just pays well. Not skimpy clothing hanging around cars looking like tart promotions :D
sup,
half an hour of sanding the lil bits of plastic and they've come up trumps! now to start the priming and painting!
how wants to lend me the digicam today? just for this afternoon!
so i can post of some pics tonight!
adrian :)
Originally posted by MrGTST
Hmmm if you are working 12 hours a day and I only work 8.... you must be making a fortune!!!! :)
dude after 3 years i'm still on a trainee wage due to dumb tight arse company
i get a decent figure but its 15k less than everyone else and I now have more experience than what half of them had when we started. its the only thing i don't like about my job.
also the last two years we have had our performance measured on afew aspects of our job, calls, cases reports, environment testing and maintence etc and i've got the best record two years running now.
Originally posted by Adrian_perth
sup,
adrian :)
what the hell u on about adrian
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
