  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no im bored so i go to the go to the guy do u have anything u want me to do - and he said write a list of what you want to learn and i'll see what i can do about showing u. I dont even know what he does!?! So yeah inhouse - thing is when it comes ot admin - not much i dont already know. I mean i dont know what im suppose to be doing - i try to look occupied but just end up whoring with u guys which aint a bad thing but still im suppose to be doing something!
Originally posted by Nizmo
your meeting me there Troy.
Not lesso sorry - someone to come appreciate the male species with me :)
i can see it now u two are gonna pinch the digi cam and take pic of guys and hopefully cars and i'll be stuck being the walking wallet and handbag
hehe
u want to get into promotions right
put that on your list :)
Hehe... If it makes you feel better I know how you feel..... I do IT where I work so basically I sit on the net 8 hours a day trying to look busy :)
nice to see your rightful place in the world Troy :)
Digicam not a bad idea, Think i may have to pinch it off dad.
hmmm wonder how many guys i can post pics of to your girls haha
Hmmm trade and investment - all you can promote here is another country *yawn* I want to get into event mangement/public relations which yes i can do here - but the line of work doesnt interest me it just pays well. Not skimpy clothing hanging around cars looking like tart promotions :D
sup,
half an hour of sanding the lil bits of plastic and they've come up trumps! now to start the priming and painting!
how wants to lend me the digicam today? just for this afternoon!
so i can post of some pics tonight!
adrian :)
Originally posted by MrGTST
Hmmm if you are working 12 hours a day and I only work 8.... you must be making a fortune!!!! :)
dude after 3 years i'm still on a trainee wage due to dumb tight arse company
i get a decent figure but its 15k less than everyone else and I now have more experience than what half of them had when we started. its the only thing i don't like about my job.
also the last two years we have had our performance measured on afew aspects of our job, calls, cases reports, environment testing and maintence etc and i've got the best record two years running now.
Originally posted by Adrian_perth
sup,
adrian :)
what the hell u on about adrian
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
