  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i went on $100 shopping spree at lunch time today kylie. Just spotted a blow off valve i want tho but now i dont have money for it oh well maybe next week or if the boys get my current one fixed it'll give me time to save to put something decent on there.
Anyway i bought a pair of kind of cargo/parachute pants from portmant but they got silk pockets and silk bits on them. And a blue top from wesco.
hahahhahhhahaha some one is fresky tonight! :lol:
saw Tanya today at uni... she looks so fine :D
hahha lol you never know might soemthing happend between you and your friend Niz...
This my friend at uni once told me she used to kiss with her best friend JUST FOR FUN! hahahah How nice... :)
Originally posted by Kyles
Ok sorry. Ill behave myself. Neighbours is on anyways and Ive gotta cook dinner.. mm.. Beef olives with a creamy mustard and parsley sauce
umm..
i already told u what happened..
and no i didnt watch it..
i copied it outta TV guide on ninemsn.com
hehe..
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
