  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Nah, we were down south, it was nice to be invited but I'd have felt a bit strange rocking up to a wedding in my SAU cap:D
I'm sure we'll here all about it in a couple days. Hope she is feeling OK after her accident.
See'ya:burnout:
Yea , I have to work on John about that.
Will see if there is an arvo session as well.
If not we might just have to run overtime . Hehehe
If I am instructing ( and atm I am ) we will be starting early ( 8 am ) to maximise track time.
Will have to post closer to the date a few details , ie pressures, loose crap etc.
Cheers
Ken
Hehe, knowing her she'd have been to drunk to have much excitement in the bedroom:D
See'ya:burnout:
Getting drunk and performing is not a female problem.
In fact quite the opposite from my experiences.
Trick is for you to remain near sober.
Cheers
Ken
Ken,
Any advice you can give us would help, we're all pretty new to this, even though we all think we're gods gift:D
See'ya:burnout:
we talking bout women or driving ??
First one , never have , never will.
Second one , some idea but still a lot to learn. At least with the 2 nd one , the goalposts don't keep moving.
Cheers
Ken
There are heaps of things I want to do to the car before the MC day, but due to my holiday funds are tight.
See'ya:burnout:
Heaps of vthings ??
Like what apart from make sure the brakes , cooling system and tyre pressures are up to scratch.
Am not interested in the fastest time cos
A , I could prolly beat you
B I could prolly beat you in your own car
C I don't want you to have no excuses when everybody else beats you.
Trick is to forget every body elses time and just work on decreasing YOUR laptime a liitle every time you try it.
Cheers
Ken
Ken,
You teech engrish asrell? Ur amoozing:p
See'ya:burnout:
Yup
I wuz top of me clarss in leeving engrish.
( Meaning I was first out the door to go home ) Hehehehe
Cheers
Ken
Ken,
No I'm not worried about power etc, or beating anyone, but my suspension setup is dreadful at the moment, and I really need it looked at. I will try Wilkinson out and see if they can fix it.
See'ya:burnout:
If it's got the usual Jap rockhards in it , he won't be able to do much. Maybe change springs.
Trick is to get some good King Springs and adjustable Bilsteins or Koni's new for about what everyone charges for 2 nd hand Teins or similar.
Cheers
Ken
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
