the boys have lifted the idle revs which has fixed the shuddering 85% theres definatley a problem there but no we dont know what it is - but as far as a quick fix this is working fairly well at the moment til i get it to tim later anyway - now ive got a spare $300 up my sleeve which is what i was going to spend on the BOV.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i think i'll just stick with the team working on my car before - they seem to do a really good job even if i do have to pay a little extra for the privledge least accurate information is being given to me :mad:
cam
as for the show thing, yeah they have club prizes and one for a new clubs etc. and some of the guys were talking about it on the sunday so theres some interest.
two of the guys were there on the weekend.
pauls interested, i thank killer-t is i am with you and zan and shuto and possible the two who were there we could get 8 and possibly one of gtrkens GTR's
Cam,
Ken simply adjusted the idle solenoid, the rev's were too low, but we checked the BOV and it appeared to be working fine. Sounded like there may have been a small air ladk, but without some spray to find it we simple bandaged the problem till it went for it's next service:D
See'ya:burnout:
Originally posted by GTS-t VSPEC
Yeah we really need a GTR, and Ken's is a real racer. We might have to do all the work for him though, cause I can't imagine Ken wanting to spend all weekend at a show.
See'ya:burnout:
next big one is the western saloon which is usually near the end of october
    • And one last super random thought, I remember when SAUNSW had a dinner with Alan Heaphy, and another with Fred Gibson there was talk of the R32 GTR cast alloy uprights failing in racing, and one of the things Fred did when they had to add weight to the vehicle was taken the failing alloy uprights, and have them made of steel. Does anyone remember back to 1990/1991/1992 and WHAT was failing in the front hubs/uprights?
    • If you truly want to know how the original failed though, was it a factory defect possibly etc, send it off for investigation. Would probably cost a shit tonne.   The ones that you need to win lotto for, unless you have a good reason for that part to be bolt on, I'd probably roll with getting a few small stitch welds carefully put in place as an extra safety factor once everything is all torqued up tight
    • Are you sure? Because I wouldn't necessarily be. Do we even know the material they've made the new uprights from?   Looking at the fractures in the earlier pics, it does to me look like both a twisting, and levering upward action doing the damage, so you're hoping for both compression, and tension. Depending on the bolts, they can stretch (even high grade bolts will) and now you're hoping for the threads themself not to stretch, as if they do, bye bye mating surfaces holding together, hello bolts now going into shear.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
