  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
those funcky vented front gaurds on GTAAH a little birdie said they are $1300 delivered and unpainted
nice but pricey
is that for a set or each skyzer?
also - anyone know where to get a good price on carbon fibre bonnets? worx have some wicked looking ones - but it seems that they have a superduper markup on them...
Originally posted by GTS-t VSPEC
Cam,
I can get them a bit cheaper, PM me if you interested:D
See'ya:burnout:
Paul - you seem to be able to get everything a bit cheaper mate! You got a container full of stuff hiding somewhere?! :mad:
hehehe *jokes*
what sort of $$ u talking? it'd be a "down the track but before car show" mod...
GTS-t VSPEC, I try to help where I can :mad:
skyzerr33, I didn't know yours was painted. Who did the job? I don't mind if mine starts peeling, only cost me a can of paint and a couple of hours of my time. If I have to do it again, I may go black with clear coat, gt-nik styles.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
