  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cool.
I waas gonna get my front camber increased to help with the MC day. I think you have said before that 3 degrees would be the max.
What do you advise I get it set to & forgetting tyre wear for the moment would you suggest I leave it set at maximum for my use as it is only a weekend car as you know.
Originally posted by Micko
Cool.
Absolute max and your tyres would last less than 10K before the insides were gone.
Would suggest you try 1.5 deg or so which will give reasonable handling and some tyre life.
Other prob with too much camber is the car wants to duck and weave on all but smooth bitumen.
Cheers
Ken
OK then - it's set to 1 degree or so now so I might leave things as they are.
Regarding the exhaust - can you suggest who I can get to make front pipes that will bolt straight to the turbs (i.e. remove the standard dumps as well) & any idea what I should pay?
You need to make it in sections , ie. the dump including wastegate bleed type pipe ( ala HKS dumps ) and then the front pipes.
Make it as one unit and you will never get them on.
Butler exhaust did a set for S dickson ( grey GTR up your way ) and SWORE he would never do another set.
Jeff Garland at Exhaust Dynamics could be worth a shot but at the end of the day , it is a lot of money for a relative small gain.
Would expect dumps and front pipe will be around $ 1500 for a good stainless setup and you will gain maybe 15KW.
Apexi power fc is about $1700 and have been told is good for 30KW.Also it 5 min job plus tuning
Cheers
Ken
I am still around doing lab write up which is due 2moro :(
cheers
Joe
here is the preview
Abstract:
The isolation and identification of bacteria from a sample of swamp water proceeded over a period of three weeks. The differential and selective methods were used to distinguish colony morphology, samples were observed under a microscope, gram and spore stains. Gram positive organisms and biochemical tests were used to distinguish gram negative organisms. From the biochemical tests, using the API 20E system, it was determined that the organism A (Isolate 1) was Pseudomonas and the organism B (Isolate 2) was Klebsiella. Using some of the characteristics observed of the isolates it was determined that the bacteria in the MSA was Staphylococcus and the bacteria in the NA was Bacillus.
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
    • Also this is my garage ornament 😁
    • @TurboTapin hey man thank you for all the info! I am about to order my cd00a today for a rb25 neo s15 build I am currently trying to get the ball rolling again on 😁 what is wrong with the Collin’s adapter? Is the bellhousing machining 15mm because that’s how thick the Collin’s adapter is or is that universal across any I decide to go with? Also do you recommend any adapter in particular? Thanks man 😃
    • Nice, looks good. Is the roof painted or wrapped? Welcome!
