  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cool.
I waas gonna get my front camber increased to help with the MC day. I think you have said before that 3 degrees would be the max.
What do you advise I get it set to & forgetting tyre wear for the moment would you suggest I leave it set at maximum for my use as it is only a weekend car as you know.
Originally posted by Micko
Cool.
Absolute max and your tyres would last less than 10K before the insides were gone.
Would suggest you try 1.5 deg or so which will give reasonable handling and some tyre life.
Other prob with too much camber is the car wants to duck and weave on all but smooth bitumen.
Cheers
Ken
OK then - it's set to 1 degree or so now so I might leave things as they are.
Regarding the exhaust - can you suggest who I can get to make front pipes that will bolt straight to the turbs (i.e. remove the standard dumps as well) & any idea what I should pay?
You need to make it in sections , ie. the dump including wastegate bleed type pipe ( ala HKS dumps ) and then the front pipes.
Make it as one unit and you will never get them on.
Butler exhaust did a set for S dickson ( grey GTR up your way ) and SWORE he would never do another set.
Jeff Garland at Exhaust Dynamics could be worth a shot but at the end of the day , it is a lot of money for a relative small gain.
Would expect dumps and front pipe will be around $ 1500 for a good stainless setup and you will gain maybe 15KW.
Apexi power fc is about $1700 and have been told is good for 30KW.Also it 5 min job plus tuning
Cheers
Ken
I am still around doing lab write up which is due 2moro :(
cheers
Joe
here is the preview
Abstract:
The isolation and identification of bacteria from a sample of swamp water proceeded over a period of three weeks. The differential and selective methods were used to distinguish colony morphology, samples were observed under a microscope, gram and spore stains. Gram positive organisms and biochemical tests were used to distinguish gram negative organisms. From the biochemical tests, using the API 20E system, it was determined that the organism A (Isolate 1) was Pseudomonas and the organism B (Isolate 2) was Klebsiella. Using some of the characteristics observed of the isolates it was determined that the bacteria in the MSA was Staphylococcus and the bacteria in the NA was Bacillus.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
