yeah i dont know why i just used to freeze up around guys i liked. Must of just been an immature thing still prefer guys to make the first move but least i dont freeze these days.
Kyles my mums weird - doesnt really care who i sleep with as lnog as its done discreetly and im no riding everybody in the neighbour hood but she cares more about what i wear - if i go out clubbing she's often - u cant go out in that u look like a **** - she's scared someone going to rape me cos im showing a bit of flesh.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahahaha i see the topic is sex again!
hahaha my parents know im a **** its a bit obvious wen u hav a different girl coming round each week! oh well they dont care mum just always tells me these stories of how her friends son made a girl pregnant and stuff like that 2 make me feel guilty
oh i used to get lectures specially when your 16 and your boyfriend 22 and my grandma got preggers at 16 by her 22 year old boyfriend - she saw history repeating itself so she always used to give me the big long in depth story on dads birth - yuk!
kyles the way some mothers speak to their daughters is so unjust! My mum has said some pretty mean thins to me too but im someone that will bite back and we'll fight it out and get it out of our system.
If she wanted me to stay innocent she should of kept her damn employees away from me - one of thems brother was boarding with us so he stayed over one night and made a grab for me in the middle of the night friggin scary thing when your 14.
yeah my friends got a mother that basically disowns her - has kicked her out on the streets many a time - and my friends a good person - far better to her folks than i have ever been to mine - she just cant understand it....... look at it this way - you'll become a better parent yourself cos your aware of it and how it made u feel ;)
