  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
ive been caught out *blushes*
Im the other side of the suburb from Ray - probably could give u the directions himself - my dad is mates with his brother.
I think after what Frank did to Rays car , I don't think there mates atm though:D
Cheers
Ken
yeah i spend too much of my time daydreaming Joe - when i used to catch the bus too and from work *shudder* I quite often miss my stop cos i was too busy off in my own world - i find it pretty hard to concentrate on anything is my problem
hahah true... you do day dream too much...
just tune out the reality, it can be bad especially when you are driving hahahahah :P hey but then again Issac newton spend his childhood day dreaming :)
haha yeah its been long time since ive been to Ray's house - when the injectors were playing up in the ZX - wish i had the many imports just lying around in my backyard ...... guess ive got two - its a start :P
I dont do it often when im driving Joe - mainly when im sick or tired. You caught me on a bad day i think.
    • Alarm installs, always great to look at 🥲 Then these alarm installers then go and do automotive looms and they end up being a crock of shit.
    • Photo quality is terrible, but there's a few things on that board that give me suspicions it has some issues. Add to that, I'm hoping the cut and exposed wires under the dash were not exposed or touching each other before you pulled that all apart.
    • Stories like this are why the immobilizer installs I've done are 100% reversible. No harness cuts.
    • update; Replaced oem starter motor with a Jaylec 70-61111 car still didn't start, moved over to the alarm system unraveled the spaghetti checked the solder end points, PCB board burn smell, wiring ends, capacitors, water damage everything looked fine restarted car vroom. restarted 5 to 6 time over an hour started put every thing back together only to not have it start any more. looks like i will be removing the alarm system next weekend.
    • Lots of people. Could be a lot of things like people have said. Either the heater hose/pipe, the turbo coolant return that wraps around the back of the engine, or a core plug. I have seen all three. If you want me to guess wildly though I would bet it's one of those hoses for the turbo coolant return. Or the brazing/welding for the Y- section has failed. Get a borescope down there to be 100% sure.
