  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
u turned up the chance of sex???
u idiot
lol no. she is reading a magazine. and it is dribbling crap about how in australia men still have to pay women maitenance if their marraige fails but its called something else. all to keep them in the lifestyle they are accustomed to or something
Psiker
