Originally posted by Psiker
hahhahah troy. it was funny when he was trying to pick niz up :D
and yes i was joking..
because what would be the point in my trying to pick niz up..
i mean.. yes she is pretty.. but..
1. i have no chance
2. she is in wa.. thus i have no chance
3. she is 18/19 something.. so i have no chance again..
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by darK
i'm trying to pick up this chick at school..
well.. actually 3.. lol
if i fail with 1.. i have 2 more.. if i fail with 2.. i have to put all my efforts into the last one.. :D
my finacee's little brother is the stud of his primary school i rekon. every day he has a different girl hanging off his arm. i cat wait the 8 years till i can take him to a club and watch him werk his magic on the unsuspecting ladies :(
Psiker
unless they find out ur playing girls off against each other
then ur dead eheh
surprisingly no........ it doesnt like the rev limiter though. and i have figured out how to get some wheelspin changing into second :( i should be ashamed :D  surprisingly also my clutch is still in good shape
Psiker
how does the rev limiter work? does it stop u car going past the redline?
haha.. wheelspin into second.. get any launching?
dark - school?
skyzer - went for a few beers at the subi, then to a mates place near uwa.. then at midnight thought it would be a good idea to go to base and drink $25 scotches.. ****in double glenfidics hurt my folding!!
then staggered home by bout 3am or somethin? how was macka's party?
1. i have no chance
dont be so negative. if a guy that looks like me can get a girl ne one can.... and distnce is no prob. remember its not cheating if its in a different post code
Psiker
my finacee's little brother is the stud of his primary school i rekon. every day he has a different girl hanging off his arm. i cat wait the 8 years till i can take him to a club and watch him werk his magic on the unsuspecting ladies :D
Psiker
hahaha... PLAYA
how old is he now
then ur dead eheh
i spose.. but right now.. i'm good friends with all of them.. so yea.. i might just take it slow..
Originally posted by caminperth
dark - school?
read my profile cam
Psiker
hehe.. right now.. i'm got no one to cheat on :D
but still... i was supposed to get set up with her little cousin.. did u read about that psiker?
hes 10 mate :( gonna be quiet the playa i rekon
Psiker
:D omfg..
really..
just wait till he hits puberty.. and he gets the acne..
then he'll be distanced from the chicks for about 2 years.. lol
where are the pics hiding skyzer??
psiker - fwd burnouts can be done one of two ways.. first way - engage handbrake, rightfoot on the foor, on the throttle of course, and dump the clutch... handbrake will hold the car in position....
second way - engage reverse, make sure you have PLENTY of room, turn steering full lock and repeat footwork without the handbrake.
:D
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
