  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey i havent hit any curbs since the ZX - ive been a very good girl- the rear was quite out of alignment tho apparently.
Nah im pretty sure they did it properly - im good friends with these guys i'll beat them up if they didnt but they are really fussy so i dont think its alignment/balance related!
Originally posted by Nizmo
haha :uh-huh:
Forgot to add
* hanging around any SAU guys under 40 *
your chances are increased with me cos I can just say to them it's ok , she's my daughter , go for it . Hehehehe
Cheers
Ken
Originally posted by GTS-t VSPEC
Niz,
I just read that your having a spa after washing your car, I could blow off the racing and come help:D I'll fix your wheels:D
See'ya:burnout:
Blowoff , ahhh pwpt60secf has returned.
Whats she gonna do for the rest of the arvo.
Cheers
Ken
Niz,
See'ya:burnout:
Are u feeling ok paul? no really? i think there mustve been a typo - i thought u said blow off racing - doesnt sound like you at all haha :)
Niz , it can ONLY be alignment , balance related.
Did they check the top arm bushes , make sure the wheel nuts were tight after they balanced the wheels , made sure they cleaned the mags before putting the wheel weights on .... ?
Cheers
Ken
Dark, If you nice to me for the rest of the week then I'll send you the CD:D
paul.. i've been nice to you since ever..
next week.. :) school holidays start soon :D
finally.. the crappy laptop comes in handy :D
Niz,
It definately sounds like alignment, nothing against your friends but you might want it checked.
See'ya:burnout:
Paul , unless the alignment is so far out it's visual theres a problem , then it is balance ie. Rotation of the wheel , not direction of the wheel.
Cheers
Ken
Niz,
I'll make an exception:D
Ken, If she was your daughter then I would be grossed out, knowing that you had sex:bahaha:
See'ya:burnout:
Face it paul , your parents had sex too.
Though I'm not sure if you know who they BOTH are...:)
Cheers
Ken
ive got a sheet with a whole lot of figures of what they checked how much each thing was adjusted by etc etc - but its in my glove box. honestly to look at the wheel all i would be seeing is a mag and a tyre - i couldnt tell all those things. I know everyone stuffs up sometimes - but these guys are really fussy - hehe even if it is another one of those places i get hottie discount at :)
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
