  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
But this is a problem that was there when the shockies went - so i thought get shockies, get alignment, get balance and it will solve the problem but it hasnt. So its not a new thing that has just happened recently since balance and alignment its been something thats been around for about 2 months :)
Originally posted by GTS-t VSPEC
Ken,
It's pretty hard to phuck up a balance, even I can use a balancer machine:D
See'ya:burnout:
Actually on mags it's quite easy to stuff it up.
They could have put the weights on without cleaning and this causes em to fly off.
As most shops dont use knock on weights , then positioning on the inner rim is critical.
Would you like a small wager that I can change the problem by swapping fronts to rears ?
That's as long as Niz hasn't left any important details out?
Cheers
Ken
Details like that!
Has this been doing it for a while ?
Does the steering wheel shake side to side or up and down ?
Cheers
Ken
Ken,
My mates own a tyre place, shouldn't be that hard for anyone who knows what there doing.
See'ya:burnout:
Paul I used to OWN a tyre shop and it is easy to get wrong if you don't know what your doing.
I am sure if I drove the car I could tell you in 5 mins where to start looking.
If you owned an Escort , you would know how critical w/bal is.
Cheers
Ken
side to side - which i guess is definately wheel related then. just pisses me off cos it is quite violent when you hit the 120km mark - which i shouldnt be doing but oh well im nauti - and thats kinda when u need everything to behave at those speeds :)
It's not brake shudder. Your car hasn't been in a crash before has it?
See'ya:burnout:
you wouldn't normally ( but who says Niz is normal ) go from 80 to 110 kmh with your foot on the brake.:)
Cheers
Ken
Yep , your learning . side to side is usually balance related , up and down is usually egged tyre/shockie related.
Cheers
Ken
accident not that i know of and it was checked out before i bought it. Ahh brake shudder - now theres something i know a little about :) im going to get new pads put on the beast soon anyway so i will get them to skim and get any shudder taken care of.
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
