  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by adam 32
ken; the whole cost from start to finish was about $400 (including head gasket and a full service i did today with plugs oil coolant etc)
it didnt cost much, just left me without a car for a month
Take into account the camshaft , vast quantities of alcohol , takeaway etc consumed by the * helpers * and it's prolly closer to $500
cheers
Ken
Originally posted by Nizmo
nah i think i mustve missed the joke in one of the posts haha cant be bothered going back to see what the joke was in the first place.
Oh boy
YOU said , paul needs glasses
I said , I have wore them since I was 14 cos I started early
PAUL said , didn't your mum tell you that it will make you go blind.....
Ohh never mind , the spontaniety is gone.:):D
Cheers
Ken
Originally posted by GTS-t VSPEC
Niz,
The joke was that Ken wanks alot, serious:D
See'ya:burnout:
Ok that had just put bad visuals into my mind.......... sometimes paul i like the fact im blonde and most things go over my head - lala land is so much nicer than reality with visuals of GTR Ken taking the dog for a walk.
Niz,
See'ya:burnout:
And continuing that inference oh paul who now wears glasses.
What have YOU been doing then ?
Cheers
Ken
Don't worry Niz , it will only be a short walk
Hehehehe
Cheers
Ken
haha my mum is snoring she sounds like a sick duck - something else i hope aint hereditry.
OK , I will bite.
What does a sick duck sound like ( and don't say your mum )
Cheers
Ken
ken that price included the camshaft. and yeh allow $50 for catering. youd have to agree despite the multiple ****-ups it didnt cost much
So $450 .
And how much would the guy who fixed it have charged you all up to do it ?
Cheers
Ken
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
