  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
I hear you keep a tight leash on your dog:p
See'ya:burnout:
I will ignore any more references to dogs , walking , chained dogs, sick dogs , and gone to the dogs.
This joke has barkcame beyond a joke and has gone to the dogs.
This will now be put down cos it's old and buried ( in the yard )
cheers
doggoner
Ken
Originally posted by Nizmo
haha i think theres going to be a lot of fustration released tonight with u too - i'll be cheering for ya :)
Niz , slow and steady wins the race ( not to mention the wifes admiration ).
Paul may be a player , but 60 secs is hard for the rest of the table to get warmed up.
Hehehe
cheers
Ken
Slapping the Salami
Spanking the Monkey
There was one to do with a dolphin cant remember what it was tho - i used to have a long list of references....... haha couldnt remember elements in the periodic table - but could remeber the long list of references to having a wank :)
ok what about reference to salami? monkeys?
Hoy you , stop encouraging him or we will both start with the
little man in the boat
2 uses for a cucumber
how can girls straighten a banana
type stuff.
so knock it ( and anyone else you feel like ) off:D
cheers
ken
Slapping the Salami
Spanking the Monkey
There was one to do with a dolphin cant remember what it was tho - i used to have a long list of references....... haha couldnt remember elements in the periodic table - but could remeber the long list of references to having a wank :D
you had better be careful or there may be a big gay wing held up by three poles at your window shortly.
Don't forget , he knows where you live and I warned you at the start he is weird.:)
cheers
Ken
he'll have to stand on his wing to get over the fence Ken :D Daddy's got his little girl pretty much locked away nicely.
haha - lucky u used the word car in their paul - that was starting to have a double meaning :)
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
