  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Cam,
Did you get the skank's numbers? We may need them for Autosalon, our club would win for sure if we had strippers handing out flyers:p
See'ya:burnout:
u really don't want these girl's numbers mate - unless u like things clean shaven... :) quite funny really...
Boat's are nice, but very expensive to maintain. I prefer friends with boats:D
See'ya:burnout:
funny u should say that.. all my friends said the same thing when i mentioned buying one.. :)
Originally posted by Nizmo
u guys realise your going to have to pay for skanks services at Autosalon?
Cam - doesnt burn if you do it right and these mints arent terribly strong anyway puuurfect haha
hmm paying for skank.. not too sure about doing that.. a mate did that last night - kicked us all out of his house cause he had a "migrane" then proceeded to go out and pay for some hanky panky.. only got caught out cause we had to go back to get my keys i'd left behind..
funny as fu
Cam,
Buck's nights almost always suck, you have to get drunk realy early to enjoy it.
Cam, Is this first hand experience with the mints burning?
See'ya:burnout:
not firsthand.. mate had a bad experience with a girlfriend who had just cleaned her teeth... hehehe.... he still winces when i bring it up...
[bboats do nothing for me - nothing more boring that when your 360 degree views are of water and sky. [/b]
u got things way wrong niz.. nothing is better than playing about at high speed on a huge boat.. 20 tonnes has alot of momentum.. :D
nothing better than being out on the ocean with some wicked tunes cranking out and a beer in hand...
mmmm boats.. :)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
