  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Oh and Adam , read my post , if Glenn is the salesman and Andrew is the computer guru , then take a guess who is going to prolly tune it.
Put it this way , Niz prolly knows as much about F Cons as Glenn.
Cheers
Ken
no the balance and the alignment made it smoother but did not fix the problem when i hit 80kms + it didnt make it worse nor better the problem was just the same.
kono kikai o shuri suru toki, sono neji o hazushite kudasai.
Originally posted by Micko
Back in a while - gotta force myself to eat the gourmet delights that the boss is serving up:)
Ooooohhh , the mind boggles .
* thoughts of Naomi on rye , *
Cheers
Ken:D
Ok , the car had a vibration at 80kmh + and you took it in.
They balanced all 4 wheels and aligned it AND put the fronts onto the back.
The vibration at 80kmh + is still there ?
Read that carefully and answer.
Did they drive the car , found it had the vibration still and THEN put the wheels onto the back or did it all at once.
cheers
we will get there
Ken
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
