joe if im not mistaken theres a lot of chinese in that last post - i learnt japanese my dear and i said my japrish aint great. Its ok Joe it will be swift and brutal not long and drawn out - u shoould find osme comfort in that thought at least haha *jk*
Niz laughs at Pauls suspension testing kit :D
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Ken - it is the pre-mixed stuff. Good for 4 years or 20,000kms. Meets many perormance requirements (as per sticker on box) & didn't seem to be any different to the other stuff.
I drained it by pulling off the bottom hose - then I realised that the radiator has a drain****...doh!
If you pulled off the hose then you got about 95% of the old stuff out so it shouldn't be a problem. I would have used the genuine Nissan stuff but I think it is all pretty much the same.
For psikers benefit , if it had been glycol based then they wont mix properly with water based ones and form an oily scum.
Cheers
Ken
hehehe , it bleeped your c o c k too !
Originally posted by 33Spec2
hahaha if it works like that id be grabbing every second girl i saw!:D
Russell - it doesnt work! as i said to joe its lucky he got me who laughed it off and not someone else cos he would have a mighty big bruise on his face by now - i may look weak but i can throw a mean punch :D
Cheers
Ken
i know this. :D was aa bad atempt at a joke :D
Psiker
Cheers
Ken
Thanks Ken - reason for the effort was that I was checking out the radiator cap yesterday & noticed that the overflow tank was empty & the radiator level was down to the core. Seems the bubbling you commented on was in fact due to a dodgy cap.
BTW - interesting that if you make your **** bigger, i.e. c o c k it doesn't bleep it out - there's gotta be a lesson in that somewhere!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
