joe if im not mistaken theres a lot of chinese in that last post - i learnt japanese my dear and i said my japrish aint great. Its ok Joe it will be swift and brutal not long and drawn out - u shoould find osme comfort in that thought at least haha *jk*
Niz laughs at Pauls suspension testing kit :D
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Ken - it is the pre-mixed stuff. Good for 4 years or 20,000kms. Meets many perormance requirements (as per sticker on box) & didn't seem to be any different to the other stuff.
I drained it by pulling off the bottom hose - then I realised that the radiator has a drain****...doh!
If you pulled off the hose then you got about 95% of the old stuff out so it shouldn't be a problem. I would have used the genuine Nissan stuff but I think it is all pretty much the same.
For psikers benefit , if it had been glycol based then they wont mix properly with water based ones and form an oily scum.
Cheers
Ken
hehehe , it bleeped your c o c k too !
Originally posted by 33Spec2
hahaha if it works like that id be grabbing every second girl i saw!:D
Russell - it doesnt work! as i said to joe its lucky he got me who laughed it off and not someone else cos he would have a mighty big bruise on his face by now - i may look weak but i can throw a mean punch :D
Cheers
Ken
i know this. :D was aa bad atempt at a joke :D
Psiker
Cheers
Ken
Thanks Ken - reason for the effort was that I was checking out the radiator cap yesterday & noticed that the overflow tank was empty & the radiator level was down to the core. Seems the bubbling you commented on was in fact due to a dodgy cap.
BTW - interesting that if you make your **** bigger, i.e. c o c k it doesn't bleep it out - there's gotta be a lesson in that somewhere!
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
