  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by SHUTO-BOY
or get an n/a 1.8 4g92, and put on a mivec head/ecu
thats what i told him. he wanted to just do the 4g15. snapped him out of that fast.
paul - yea. i dont want to act like an adult, thats why i took the whole weekend of work just for my party. 2 day party bring it on~~~!!!!
Psiker
Originally posted by Psiker
also. a freind of mine asked this of me. could u guys recomend someone to do a 1.8l mivec conversion to a mirage? i tried to sway him from it but hes hell bent on it as he love mirages!!!!
Psiker
Try Mal crockenberg
Crockenberg Motors
John St
Welshpool.
Is the Ralliart agent in W A and has done that conversion to a colt or something similar.
I believe is a bit more work than you think.
Cheers
Ken
Originally posted by Nizmo
i feel like wine tonight. :P my cats gone to bed without me - the bloomin thing sits at my bedroom door and howls til i let her in - she loves sleeping on my spare set of skyline floor mats - the cats got taste!
wine........ xanadu!
cat- do you have photo of your mossie?
Originally posted by GTS-t VSPEC
Psiker,
I'll see him tommorow, I'll ask him who much, but it is never cheap to do a conversion:D
See'ya:burnout:
mmmmm. he was praying after the drags that the box was farked ne way :P is leaking tranny fluid everywhere and skipping from second to third for no reason. he was runnin constant 15's wit 3 second 60 foots. but a terminal speed of 157kmph
Psiker
Originally posted by osc@r
Ken,  it's a sr20det silvia..
jumps out of reverse, feels like it's not fully selecting it.  All other gears feel perfect.
Only done 70thou k's.
Does it go into 5 th further than 1st or 3rd ?
Cheers
Ken
Originally posted by gtrken
Try Mal crockenberg
Crockenberg Motors
John St
Welshpool.
Cheers
Ken
thanx ken ill tell him. i rekon it would be pretty hard also. but he has the cash to burn and really wants to do it. so i want to send him to the right ppl. dont want im to get too stuffed around :P
Psiker
Niz,
What word would you use?
See'ya:burnout:
molest :P
Joe i'll see if i can dig up a photo of zenah - she's just a tortiseshell moggy tho - but she's god damn smart - too smart for her own good!
aidwin yeah i like sweet white wine - not too fussed on reds - but they say u acquire a taste for red when your old haha wine leaves u with a shocking hangover tho.
if you like sweet white wine then no doubt you should try the noble rising from Xanadu or Pikes.
red = :spew:
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
