  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
Niz , if you like sweet white,
Brown Bros Crouchen Reisling is great.
Wife thinks it's good as she is a sweet white lover
cheers
Ken
yeah had that ken nice drop. Orange Muscat Floras yummy as well cant remember who makes it - i remember the label tho.
Originally posted by Nizmo
yeah got shadows balls cut off poor boy we werent content with doing that - we had to shave the cat as well - he looked shocking, he got his revenge tho he pissed in my car when we moved haha We had to get him shaved cos he had really long hair and he would stay out for 2 weeks at a time in bonking and fighting sprees and come back with his hair all matted and past brushable.
I've shaved few pussies when I worked at VET :P
Lion clip is my favorite...:P or was that landing strip :P
dont remember but it was fun! :D
Originally posted by 33Spec2
hello niz hello paul
thanx 4 your help paul i owe you a drink!:P
had a look at it when i got home - by the way wat is the third wire coming out the cig lighter? the red and black one?
anyway will finish it on friday arvo coz i wanna hav it done 4 friday nite
Obviously you did not read my post b4! shows how much attention u pay!:P
also i have these wires that come up under the drivers seat does anyone know wat these are 4???
Sorry Ken.. i didn't see the question.
No the stick goes into all forward gears perfectly.. all equi-distant. feels like a brand new box.can't tell anything is wrong until trying to select reverse...then it only seems to go about1/2 the usual travel and then as i disengage the clutch, she jumps out.
Originally posted by Kyles
what the hell where you doing with thoes cats joe??
Kyles remind troy boy about a certain debt he owes me b4 he gets you a pressie.
Hmmm , maybe I had better remind him myself:D
Cheers
Ken
awww your cats cute psiker - mines got black and white pretty muc in the same places just its got orange on her as well but she's mostly black and twice your cats size.
She doesnt like anyone but me only comes when i call her - its funny my mum stands a the front door calling her and she wont come in and goes ot me lauren call your bloody cat will u as soon as i call her she's in like a shot. But her and i have a bit of a bond - she picked me i didnt pick her haha
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
