  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Strich9ine
YAY!!!!!!!!!!!!!!!!!!!!!
Booked my clutch in for Thursday morning at Auto Clutch!
DCB 9puck clutch with 2500lbs pressure plate, re-machined flywheel, and thrust bearing..
so all should be right for friday's cruise.... just hope i can "bed it in" before then!
How much was it?
Originally posted by skyzerr33
that setup will be about $850 for kym dan
we should call ross and tell him what a twit kym is so he charges more hehe
AHAHAHAAHAH!!! :-)
the one that PSI did for me is 2600lbs... i have gotten really used to it now :-) i think mine came up to about 850 aswell but brett used a REALLY good quality one and is really not that hard to push in! Troy next time you hoon past gimme a call and i will let ya feel my clutch! not crutch ahahha!tell me what you think of it..
i hated it 1st of all but really am getting used to it... it's a lot different from a hyundai clutch Kim :-)
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
