  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahaha we all in for 1000 hey? hahahahahaa un****ing believable who would have thought a lil page would be worth so much? hehehehehe :mad:
adrian :mad:
i'm gonna win, i'm gonna win (turns around winds up his nos bottle, checks nitrous pressure, over runs the start line has to reverse back like a loser) heheheh :(
Originally posted by GTS-t VSPEC
Niz,
your probably right, but this server is better than the old one:D
Dan,
If it's not raining I might, who from the RB's are going?
See'ya:burnout:
the G4orse supra will be there, i will go, ummm a few others am hoping ND4SPD goes!!! would like to see it... a few good ones but a few bad ones too, the event is mainly to have fun so you can expect a few 20 sec passes if not from me from someone else..also my friend with a semi worked EF xr6 not bad for a NA 6 hoping for low 14 on that one!
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
