  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
sounds like half the people i work with and thats on a good day haha tell u some people i see that smoke is enough to put me off it - wrinkles and horrible skin and f-up voices yuk
I hate the frekin yellow teeth and fingers!! yack :spew:
especially smell... I cant stand the damm nicotin smell! :spew:
psiker - hehehe... you got it in one.. :)
well if we aren't good enuff for to u whore with niz.. nite nite...
in fact i've got back to back meeting for about 3 hours tomorrow morning.. need to be able to not yawn... so am going beddy byes..
nite guys...
oks cam. Just didnt seem you where exepting my opion. :) its kewl. Your intitled to yours 2. But hehe i will neva back down in a debate .. My best friend and i get in one you can shut us up on it lol its soo funny the only way we stop is when we both burst out laughing with the silly facts and come backs we end up coming up with cos we have run out of things to say.
Goodnight everyone
spend a day at work with me.. baby drool, vomit, poo, wee, snotty noses, messy fingers and children hugging you..
No wonder i come home looking like a grub.. covered in all sorts of stuff.. today slobber and paint and somthing else no idear what it is.
i can put up wit hthat. its not their fault :)
jut ppl who do things that they know are bad for em but keep doin it annoy me. i dont know if im sposed to feel bad for em or shun them
Psiker
that's why I dont work with children, but I work with animal :)
hehehehe....
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
