Originally posted by Pva_Glue
Those chicken are fed steroids so they can bulk up most amount of muscle in shortest time...
or even sicentist made featherless chickens... so they dont have to pull the feathers out ... lazy! hahah.
there not suppose to do that anymore
can lead to the birds have msg which can poison humans
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by SHUTO-BOY
is it even chicken?
They are genetically modified chicken!
last week in my molecular biology... we had to test the contents of pate made from quail meat.
work out how much quail meat in the pate. by diagesting the DNA contens with enzymes then comparing with known DNA of quil...
hahahah its very complicated process and boring!!!
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
