Make it ureself even. the only logical reason is for the Salon in which case it need to look nice and all.
Oh and when u first install it make sure u carry a fire extingusiher on the maiden voyage. u never know
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i jsut used to order my lunch and hughsies lunch to come together eat it in the office n surf the net - the days before whoring :) i used to walk the hill a bit too but going past broken hill is really dodgy.
Originally posted by Nizmo
$293 on beer - i think your going to need some help drinking that much beer *hint hint* haha :)
I need no help
FOOLISH MORTALS BOW DOWN BEFORE THE ALMIGHTY BPU.:bahaha:
Hey if ure not driving ill prolly be hanging out of gradenkos car like a goon. illl toss a berr ure way tomorrow. if it doesnt rain.
GTS-t VSPEC, vacum through the oil breather hose? I sure hope you've blocked off/pulled out your pcv valve, cause otherwise you're just sucking oil vapour and unfiltered air back into the plenum chamber. If you've yanked the pcv, then there shouldn't be much vacum to worry about.
I'd still be getting heavy duty hose instead of the clear stuff. Looks a whole lot more "stock" whith thick black hose and no chance of hot oil causing problems.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
