  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
Mr'Ken I yet to see this video footages of last cruise! :P
where are they?
It was only the bit with pwpt60secf and me and is about 1 minute worth.
Paul has the CD but can't open it.
Makes you wonder doesn't it , being a coputer nerd teacher and all ?:D
Cheers
Ken
