  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by SHUTO-BOY
ur hyundai,not really ,id call it Australian delivered,maybe the ecu is de-tuned to suit australian fuel
the sickest hyundai i saw was a hyundai coupe with 4g63,am i giving u some ideas?
ahah no. i am refusing to do any mods to my car :) i get enuff flaming. id rather spend the money on something that will go fast stock :)
Psiker
psiker: what did u dad say to the blue fuzz again? i must get his punch line.
i dont know hey. but apparantly he was real polite to him. and the copper was gonna give him 150 and 3. but instead came back and sed. ill tell u what. i know sau are cruising tonight. I can see ur an "older" member of the group. if u get em to slow down for the rest of the night ill let ya off :)
Psiker
the nicest thing a cop did to me when i got stopped was, checked my ride height(with tape measure), then checked for my cat, then let me off
really. thats a nice cop. nicest thing a cop has done for me is only given me 4 points for doin 110 over the speed limit. im my younger p plate days
Psiker
Psiker: thats serious, hmm were getting a bit of a bad rep, i think we should do more charity stuff
yeah i know. i can beleive also that the police browse these forums thats why u have to be careful what u say. maps should never be posted
dark : its all innocent mate :) im a almost married man
Psiker
