  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
How long you guys parte? last night?
I had to home early on EVO4 WRX :D Imacula8 is married man so early night and I had to work this morning... :D
pfft i didnt party at all. had to go home. journey home hurt. never try to fit 4 ppl into a mkIV suplah
Psiker
