  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Everyone has those Louis Vuitton Handbags :)
Scott and I were shopping in subiaco spied this versace top - which i thought was fag richboy looking but anyway - had a price tag $1500 haha you would be pissed if u got grease on that one :)
Originally posted by caminperth
joe - i know that.. i think my other half has the record for the most expensive handbag.. put it this way - for the price i could buy a NEW turbo!! *sob*
you damm right you are!
Those LV scarf can buy you new tires
Those LV glass case can buy you new ECU
Those LV hand bags can buy you new IC & Turbo...
and set of travelling bags can buy you R34 GTT
:bahaha:
i have two handbags both about $25 - even i think thats too much on a handbag! My most expensive purchase in clothing was a $300 evening gown. Refuse to spend over $150 on an item and then it has to be something REALLY worth it!
joe - tho unlike you, i didn't have to spend the $$ on it.. but watching it happen was enough to make me cry...
heheh you lucky dog... you didnt get sucked in :)
well I did :) No regrets but its a lota $$$
have to ask yourself, if that is worth it!
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
