  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nope , wasn't me who got the kerb.
btw , ran across a bunch of silvias etc up Tonkin on the way home.
If that was the Jap spec cruise , then there is a problem with calling US pussies
Cheers
Ken
Originally posted by GTS-t VSPEC
Hi Ken,
Did you get home OK, no accidental drift action? How does the GTR cope in the wet, better than the GTS-t I noticed:D
See'ya:burnout:
Traction is better than 2wd in the wet ( no one chopped me ) but it is not infallible.
Cheers
ken
Hehe, did you chop the Jap Spec boys?
Yeah, well my car really struggled with traction, but it was a fun, relative incident free night with a decent turnout:D
See'ya:burnout:
Yea , it was a shame about the weather but for those a little brave , it gives an opportunity to test the grip limits at low speed.
cheers
Ken
Please don't do an age count, that was stupid:p Plus you'd take us past page 2000:D
See'ya:burnout:
N ah , just kidding but the whores were out today .
Something like 25 pages.Took ages to wade thru the bullshit
Cheers
Ken
Yes, the wet let's you get sideways at very low speed, and showed some of the guys they have much to learn:D
I can't wait to get on the track and learn how to drive better:D
See'ya:burnout:
After seeing Shuto's , Niz's and your posts along with Micko , I am getting a little worried.
This session is not going to magically improve your skills.
It took me bloody years and a few wiped out cars to get to this level of stupidity and I am nowhere near the top of the tree.
Cheers
Ken
Don't start age counting Ken:p  I watched that drift stuff from Gradenko, it's awesome, did you get a copy?
See'ya:burnout:
No but I should have , was it some local guys in a local private road ?
Cheers
Ken
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
