  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nope , wasn't me who got the kerb.
btw , ran across a bunch of silvias etc up Tonkin on the way home.
If that was the Jap spec cruise , then there is a problem with calling US pussies
Cheers
Ken
Originally posted by GTS-t VSPEC
Hi Ken,
Did you get home OK, no accidental drift action? How does the GTR cope in the wet, better than the GTS-t I noticed:D
See'ya:burnout:
Traction is better than 2wd in the wet ( no one chopped me ) but it is not infallible.
Cheers
ken
Hehe, did you chop the Jap Spec boys?
Yeah, well my car really struggled with traction, but it was a fun, relative incident free night with a decent turnout:D
See'ya:burnout:
Yea , it was a shame about the weather but for those a little brave , it gives an opportunity to test the grip limits at low speed.
cheers
Ken
Please don't do an age count, that was stupid:p Plus you'd take us past page 2000:D
See'ya:burnout:
N ah , just kidding but the whores were out today .
Something like 25 pages.Took ages to wade thru the bullshit
Cheers
Ken
Yes, the wet let's you get sideways at very low speed, and showed some of the guys they have much to learn:D
I can't wait to get on the track and learn how to drive better:D
See'ya:burnout:
After seeing Shuto's , Niz's and your posts along with Micko , I am getting a little worried.
This session is not going to magically improve your skills.
It took me bloody years and a few wiped out cars to get to this level of stupidity and I am nowhere near the top of the tree.
Cheers
Ken
Don't start age counting Ken:p  I watched that drift stuff from Gradenko, it's awesome, did you get a copy?
See'ya:burnout:
No but I should have , was it some local guys in a local private road ?
Cheers
Ken
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
