  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Neo
I though that C-red did there own compliance? I saw a new silvia that they brought in at another shop? Anyone?
Ken,
can we see you in action at any of the tune days at waneroo?
They only hold compliance for a certain range of cars.
Blue S15's aren't one of them.
Cheers
Ken
Originally posted by GTS-t VSPEC
Neo,
With the new rules then most people won't be able to do the compliancing, only accredited workshops:D
Ken, Sure, another pointless thread can't hurt:D
See'ya:burnout:
Hey if eriktosser can get a thread on freek ( or *****ng whatever) , the Troy has to be worth a little bit of bandwidth.
Cheers
Ken
Ken,
I don't do Wanners pers'e but when the Enjo SES goes there , then I will.
I am hoping the SES Collie circuit and Wellington dam on the 26th -27th April is my next one.
Cheers
ken
Hehe, It's a pity erik didn't show last night, I had a few words of advice for him:D
Why don't you start the thread, you scared?:D
See'ya:burnout:
Advice like
You , your mate , your dog , your horse , your bbq AND your skyline and it's plates , F**CKOFF !!
Cheers
Ken
Ken,
If I'm free I'll try and make it down, will you have the 4WD to toe it by then?
See'ya:burnout:
Yep , I already got it.
Picked it up yesterday.
Gotta love the petrol guzzling maverick/Patrol.
Cheers
ken
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
